I think that you have lost the plot with your reasoning. You appear to be the sort of guy who pleads innocence all the way to the gallows, just to get the last word - causes a row in an empty hoose as they say!It's reasonable to make allowances for the paving being removed at some point in the future."Buried cables, conduits and ducts shall be at sufficient depth to avoid being damaged by any reasonable disturbance of the ground"
Under paving with marking tape on top? You'll have to do better than that!
At which point, marker tape or not, less than one spade depth down is not enough.
Err... where, exactly?I did.......... you criticised!
It's good that you are using an electrician, but you must speak to her now, and get her to make the decisions about cable selection and routing, because she will be the one who has to sign it all off as her work, and being compliant.If you expect an electrician to sign it off then he must be involved from the very start and he must be the one to make all the design and installation decisions.OK - since you seem unable to understand this without it being explained in very simple terms, I'll do that.Sarcasm doesn't help your case!ban-all-sheds said:And oh look - you didn't write "he/she".....
1) In here I have written "It's good that you are using an electrician, but you must speak to her now"
2) I have also written "If you expect an electrician to sign it off then he must be involved from the very start"
3) You have written "If he gave a quote.."
So given (3), and the fact that you only questioned why I derived a female electrician after (1) and not why I derived a male one after (2), do you suffer from an ignorant and primitive gender bias?
Get well soon.
Regards
