can i use thermalite blocks as trench blocks
8 Jun 2018
hi all
im building a large gym in my garden which is 9.7m by 3.8m
i have dug the trenches and they are 800mm deep which the building inspector is happy with.
he has said i can trench fill upto 400mm and trench block the rest.
ive been offered some thermalite blocks 3.6n could i use these as thrench blocks.
thanks for any advice
now i could be miles out
but i believe they need to be above dpm level as they are fairly light weight
Yes, but not in the frost zone 225mm above and below ground level on the outer leaf.
Did they report on the small line of block dust on the ground caused by several freeze/thaw cycles?
Presumably it gets to be a bigger line over the years.
I built a shelter for the wife's call ducks with some old Thermalite and concrete blocks that had been lying around for quite a few years, but the Thermalite were a lot more crumbly than you would expect for a new block, so I'm not totally convinced by the manufacturers claims.
You and Woody might be right to be sceptical. As I said, I have only used them once and the structure was rendered.
Even if you could, you'd be left with a course of blocks on show.
