    Dismiss Notice
Can not get the cap off mixer taps
Discussion in 'Plumbing and Central Heating' started by rustysul, 10 Jun 2020.
  1. rustysul
    rustysul
    25 Apr 2006
    8
    Thanks Received:
    Cardiff
    Country:
    7EE9CECA-B706-45E2-8740-7776D9441335.jpeg BD22EF61-9E40-4866-BF0E-F5B8FC9D895D.jpeg tried everything to get the cap off these mixer taps, any suggestions please.
  2. Sponsored Links
  3. picasso
    picasso
    8 Apr 2008
    10,584
    Thanks Received:
    2,647
    Essex
    Country:
    Try unscrewing the "arms " of the tap sometimes the manufacturers hide the grub screw there.
    • Like Like x 1
  4. terryplumb
    terryplumb
    8 May 2017
    5,962
    Thanks Received:
    1,230
    Country:
    Prise off the cap ( with C / or H on). There's a screw underneath that needs removing to allow the cross head handle to pull off the valve.
  5. just pumps
    just pumps
    24 May 2016
    2,907
    Thanks Received:
    496
    Country:
    You tried removing the dome on the end of the tap? Might take boiling hot water and a rubber glove for grip. Prise off or unscrew.
    Edit, once again two people typing at same time.
  6. ljrgas
    ljrgas
    12 Jan 2010
    2,330
    Thanks Received:
    339
    Country:
    do you mean cap off out fix? you can cut the pipes under the taps and cap. or you can just replace the heads/inserts
  7. rustysul
    rustysul
    25 Apr 2006
    8
    Thanks Received:
    Cardiff
    Country:
    Cold tap leaking,just can’t get the dome cap off, and wasn’t 100% that was where the screw is. If someone can tell me 100% that’s where the screw is I will persevere and remove dome cap.
    Tried taking little handles from the tap for grub screw ,but nothing there.
  8. oldbuffer
    oldbuffer
    6 May 2010
    1,393
    Thanks Received:
    523
    London
    Country:
    1. See if round chrome shroud below handles will unscrew. If it does, handle may come off with it.
    2. If not, domed cap above handles may unscrew rather than being a push fit.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
