If when balancing my rads I find that ALL rads heat up nice and hot with both valves open is this ok ?
Or does the flow in radiators NEED to be restricted for any reason?
The reason I ask is that when balancing the rads with all valves open all rads are hot apart from one small one. I can get this one hot very easily by restricting a couple of rads up stairs. Is this good?
My concern is taht perhaps the water needs to flow through a rad slow enough to disipate the correct amount of heat ????
If i can measure the temp of all rads and they are all the same with all valves open is this ok ?
Hope someone understands what i am trying to get at !
Cheers.
Cheers.
