Can see difference between brush and roller on new render
26 Apr 2016
Hi I wonder if someone can help me.
Just had the outside of my house rendered and painted. The painters used a brush round the windows and then used a roller on the larger parts of the wall.
When I look up at it close up, from my patio, I can clearly see the difference , when I look from the bottom of my garden , 100 ft away, I can't see any difference.
Is this normal?
Sort of, but not quite. They use the brush round the window for neatness, but should take the roller as close to the window as possible. You're never going to get a perfect solution, but I suspect it should be better than it is. Can you post a picture.
Thanks for the reply, had the boss round today and he thought it was a bit patchy in places so we will be getting the painters back to look at it.
