Can wall track be plastered invisibly?
19 Feb 2015
Consider a 10/12cm wide track which is cut from the ceiling to floor on a lath & plaster wall to access pipes. Afterwards I could then glue back in 10/12 cm long lath sections to adjoin the laths which remain in the wall.
I could then put on a coat of primary plaster to just below wall surface.
Consequently I could get a professional plasterer to put on a finishing coat of plaster and then I could emulsion the entire wall afterwards.
If this is done, do you think the track will still be visible? I just wondering whether I should have the full lath/plaster wall removed then boarded/plastered afterwards to avoid a visible track line.
Thanks.
..... or you could use a heavily-patterned wallpaper to disguise any slight surface discrepancy.
OK sounds attractive as a "route" but?
There is always a BUT??
If you consider the mechanics of a Lath & Plaster wall, it relies on the matrix of timber [horizontal] Lath fixed to the [vertical] studs which are in turn fixed to the masonry wall, with the plaster over all.
If you introduce a vertical "cut" which affects all of the laths, the wall will become unstable on each side of the cut away Lath, you could try to introduce a further [vertical] restraint but? not all that easy, especially when the plaster crumbles when you put a screw into the plaster, through the Lath into the "new" vertical stud??
Short answer is unfortunately Yes.
Ken.
Ken.
If that's the case it's probably best to remove both the lath and plaster from that side of the wall then have the full wall boarded onto the studs and plastered to give a clean finish.
Possom, good evening again.
Two possibilities that I can imagine?
1/. [not great] form a duct out of ply / mdf on the external face of the lath and Plaster?? in effect a mock pillar??
2/. Depending on cost and outcome? remove the existing Lath & Plaster and if it is an external wall re-fit using "modern" metal [vertical] studs and install insulated plasterboard + loose slab insulation with the pipes, suitably insulated + concealed
A vapour barrier will be advisable between the rear of the insulation and the inner face of the wall.
Just a consideration??
Ken.
It's an internal non-load bearing wall. I may remove the lath and plaster, retain the existing timber studs then have plasterboard screwed onto these then subsequently plastered.
