I've got a combi boiler system and have moved pipes around, new radiators, etc. Bit broke now and can't afford the power flush. Can I connect a hosepipe to the drain point in the return pipe pipe below the boiler, cut into the outgoing water pipe from the boiler and add another "drain point", then hook a hosepipe up to it from the mains and flush the system with mains water pressure and expect a fairly good result?
