Can you notch/ drill into a flitch beam?
6 Jan 2008
London
I've just notched my joists to allow a reroute of my central heating. However, the last joist turned out to be a flitch beam ( as just suggested by someone helpful in the plumbing forum).
Re routing over or under it would be a complete nightmare as it runs the full width of the house. Is it possible to notch or drill a hole in the beam to allow the CH pipes though or am I just going to have to go over it?
As the beam will contain a steel plate, notching it will be difficult if you hit the steel. Drilling holes through it should be OK for load bearing but difficult to do. You will need an annular cutter or a tank cutter. Drill the hole right through the centre of the beam (top to bottom) as it does not weaken the beam. So a couple of 16/23 mm holes spaced by 3"? Will you be able to thread your pipes through the holes?
Frank
Thanks for the reply, much appreciated. I agree that, in principle, it should be ok, given that the steel plate has holes in it for the bolts and electric cables. I've got Starrett cutters at work and, although it would be a major faff, I think it's doable.
However, I'm going to proceed with caution. A friend of a friend is a surveyor so I'm going to consult with them before I do anything, one way or the other.
