I would appreciate any ideas regarding this annoying problem.
My Candy cfs 4570 EX dishwasher fills and then stops (as the water level valve clicks), then there is a 1 minute pause, followed by the water being pumped out. The machine does this twice and then the first 2 lights flash - indicating there's not enough water inside. I have adjusted the water level valve to the maximum level of water allowed in the dishwasher, and still the problem persists.
Can the Water level valve be faulty even though it switches and stops the water?? Are there any other kinds of flow meters in this dishwasher?
The water level valve did have some water inside it, but I dried it and tested it and all seems to be good, but maybe in operation it's faulty?
Thank you
Thank you
