I'm going to rewire it so that the pir has a permanent live. If that doesn't work then I'll simply put the pir and switch in parallel and use the switch in on position to provide the manual override.
Anyone give an insight as to what's going on with this? Can't be two faulty units, surely?
I've left it wired up as per the work around that Taylortwocities mentioned earler in this thread but I'd like to know (cos that's the way I am) how to get it working the way the factory intended.
This will bug me until I know what I'm doing wrong.
