hi
just built a large gazebo/shed structure, really happy with it but unfortunately the roof leaks. i just cant fathom it, nor can a builder friend of mine who's had a look at it.
its a relatively shallow pitched pent roof, dropping 1ft over 3.5m. the roof is comprised of 4x2 joists and noggins, 12mm wpb ply, then wickes 'super' shed felt, mineral i think. 4 layers going horizontally, overlapped the correct way and stuck down on the overlaps with felt adhesive and clout nailed on overlaps and at the side.
since it started leaking ive gone over every clout head with sealant, and also sealed up the overlap seams too.
the only thing ive been told it can be is either capillary action at the overlaps, but i refuse to believe water can break through that seal AND run uphill! OR......getting past the sealed clout heads.
could anyone give me any advice as to what you think could be the problem please? im tearing my hair out here!!
i can supply pics of any areas you may think relevant
thanks a lot
EDIT: the water seems to be running down joists then spreading across ply, which implies its getting in higher up, but cant be sure if thats at the front or the first overlap.
thanks a lot
