carving large tree stump - which tools?
1 Apr 2008
Devon
I've a softwood tree cut down to approx 10 foot, with a chair shape roughed out by the tree surgeon. I want to shape it - taking out up to 6" in places - mostly in the internal chair space.
I'm not going to use a chainsaw - never used one before, difficult access.
I've looked at the scary attachments for minigrinders: woodsaw disks, chainsaw disks, and decided against those on safety grounds, and having seen someone using an arbortech grinder I'm inclined not to try that either.
My jigsaw isn't really up to it, and I can't get it into the corners.
I've had some success with a sharp chisel (wood is still green), but there's a lot to remove so it'll take a long time, especially with grain running all over the place, and I've got a cheap multitool from screwfix, which I'm sure will help.
Any other ideas?
Cheers,
Stephen
There s a reason all of this work is done with chainsaws.
Any sort of plunge cut or cuts into corners is almost impossible with other tools.
Please please steer clear of any electrical tool with a rotating blade or tool without a clutch.
A good quality pruning saw like a silky may be of good use buy will be pretty labouriuos and very hard into the corners.
Whilst it may seem daunting a small 10'' light chainsaw is ironically probably safer if you work carefully and methodically than the wrong tools.
Thanks, yes, helpful - I think I'll call in a (professional) friend with a small electric chainsaw for a couple of hours of paid work.
Another option would be to drill out the bulk of the stump using a corded drill and say a one inch bit ( not a flat bit) and clean up with your chisels.
