Catnic Cougar lintel on timber?
26 Sep 2004
Is it ok to install a CG lintel directly beneath a timber wall plate or is there a minimum amount of brickwork required between the two?
Cheers, J
These lintels are designed to have some masonry on them.
If the upstand is not going to be in the way, then is would really depend on the actual span and the load/point load details. Up to a metre span might be OK, but it depends
Catnic have a technical department. Give them call and they will tell you whether or not the lintel is suitable.
