Caulk or silicone? New Kitchen
3 Apr 2023
Hi all,
I have had a new kitchen fitted. Where the new wall cupboards meet the painted wall, and where the upstands along counters meet the same painted walls, I need to know whether to:
a) use No Nonsense decorators caulk and then paint it. Bearing in mind that the caulk bead will be half on the cupboards (white) / upstands (wood effect), and half on the adjoining walls so painting it might not look quite right?
b) use clear silicone, or maybe a light grey like manhatten as the walls are a very light grey colour.
Thoughts?
Many thanks
Where the wall cupboards meet the wall I would paint first then run a bead of silicone, either clear or colour matched to the cupboards. If you decide on caulk, to enable over painting, I would run a bead after painting so that it looks neat.
Thanks for the reply.
The walls are already painted. Done a week ago. Walls are a light grey sort of colour and cupboards white.
Which would your preference be, silicone or caulk that then gets painted?
Silicone should never be used any near a surface that needs to be painted (or repainted).
I would recommend either caulk, or a MS polymer. The latter being more flexible (eg CT1). Use very thin tape when applying it to maintain a straight edge. Remove the tape whist the MS polymer is still wet and smooth it again.
BTW, I am a decorator.
