We recently moved into a 70's 60 sq m 2 bed semi bungalow which has cavity walls.
No insulation so we were considering CWI, however apparently we'd have to have trickle vents fitted to all windows, which we don't really want , however we would qualify for it to be done for nothing. We have had it suggested to us that we buy trickle vents and temporarily stick them to the window frames prior to the CWI firm coming to do the survey.
We had 3 windows made smaller, plus 2 of the other windows had pvc cladding below them down to DPC level and there was no outer course of bricks ,so we ripped that off and created a cavity. All the new block work is breezeblock as we couldn't get a good brick match. The plan is to render in the spring so we were thinking of getting some quotes for insulated render.
The room that's really cold (it warms up when the rad's on, but cools down really quickly )is the only room with 2 external walls which is a bedroom facing SW so it gets battered by the wind. One of the external walls in particular feels very cold to the touch, so cold that we've moved the bed over to the other wall.
Any thoughts please?
