- Joined
- 26 Mar 2020
- Messages
- 39
- Reaction score
- 1
- Country
New single storey side extension (wc/ utility & office) with tiled pitched roof (inc breathable membrane/felt) with rafters & ceiling joists
So small void /storage area potentially all be it small, and insulation is priority
Double skin (Con. blocks, cavity insulation , Fenlite Con blocks,)
& floor to current insulation requirements etc etc
CEILING ??
Specified is :
300mm of insulation roll in two layers;
One between ceiling joists, then next layer over joists.
Is this best solution ?
what about celotex , foam backed p/board , or foil quilt products
INTERNAL WALLS? (Even though double skin & insulated)
Whats best method of adding insulation internally (just to improve u values etc)
Foam backed plasterboard ?
25mm celotex , then p/board w/ instastik or mechanical fix ?
DONT WANT TO batten out - defeats the object
CEILING ??
Specified is :
