Ceiling & Coving 2nd Coat?
dk3
13 Jul 2006
Hi. Should I give ceiling and coving a 2nd coat as standard or is it worth deciding after 1st coat is dry and see if it will suffice? Will be painting white on to existing white. ta
Depends how dirty the ceiling is. Sometimes it may go in one coat if its not had much fuming or staining from gas fires, central heating etc. Let the first coat dry then decide if you need to do a second.
Always 2nd coat, there's always an area which is a bit light of paint.
