Hi
I'm currently redecoration my front room, the walls are not cavity walls so heat retention is almost non existent
I've pulled all the lathe and plaster off the walls and ceiling, with the intention of creating an insulated internal wall and was going to put insulation fiberglass in the ceiling before I put plasterboard up
If I'm insulating the ceiling (bedroom above), do I need to think about a vapour barrier?
Would solid insulation boards be better?
Do I need to have gaps around the lights (going to install downright)
Chris
Chris
