Ceiling lights turn on and off by themselves
17 Mar 2012
Yorkshire
Hiya
After recently changing 5 out of the 12 Diall Halogen bulbs in our ceiling light, the lights now turn themselves out, and back on again on their own, it's not like being in a disco, they'll stay on for something like 20 minutes and then turn off for 20 minutes, then back on again and so on. They worked perfectly fine before we changed the bulbs.
Do any of you know what the problem could be?
Thank you in advance.
Are these 12v lamps?
My guess is that you have put in the wrong wattage lamps and the transformer is now overloaded.
Check you have replaced with exactly the same wattage lamps as the old ones.
Yep, you have replaced the lamps with ones of an incorrect wattage, overloading the transformer. The transformers thermal cutout then operates, the transformer cools, the cutout resets itself.
Change the lamps for the correct wattage.
On some multi lamp fittings, it is common to find 10w capsule lamps, but most stores only stock 20w, so people seem to just buy and fit these (incorrectly).
Thank you both for your help. You're absolutely right, I had replaced them with 20w instead of 10w. I'll go and get some new bulbs now.
I just bought the wrong ones. I didn't check which I needed before I bought them, the shop only sold 20w and above so I got the 20w. It was a mistake.
