Hi
Confident and competent DIY'er here hoping for a bit of up to date advice please ??
I've turned a small section of my new block built garage into a utility room with a bog standard stud wall. I want to plasterboard the roof trusses and the stud wall part of the utility room for insulation and aesthetics. Now this might be a daft question for those in the trade, but do I plasterboard the ceiling or wall first, what's best practice ?? And rather than use 9.5mm on the ceiling, is it ok just to use 12.5mm for everything ??
Having just read a few posts about the subject, I've noticed I've got almost 600mm centres on the wall and ceiling. Should I just go with 15mm plasterboard ?? Cost isn't an issue, doing the job right is
Cheers
Cheers
