Hi, I had a look at the wiki page and didn't think I could see the diagram for what I'm looking for so I thought I'd ask here.
Right.
I've got two light fittings in a hallway. At one end of the hall is a 1 gang 2 way switch that switches both hall way lights on and off.
down the other end is a 2 gang 2 way switch. One of the switches controls the hallway lights. The other controls the lights and extractor fan in the adjacent bathroom just off the corridor.
I'm replacing both light fittings in the hall way. The first fitting located at the bathroom end was a simple change with there only being a single L N E in the old ceiling rose.
Im pretty sure i know what to do with The other fitting but wanted to double check what appears to be the switched live and and another live going into the
Same terminal. (See the red and black wires at the right side of the pic)
I'm using wago connectors as I'm doing a load of lights and these save messing about with screwdrivers whilst up a ladder.
Assuming I've connected all the other wires
Would I just connect these two wires together using a two way connector
cheers
View media item 77055
Right.
cheers
