Hi all, I had a feel of a radiator behind one of the sofas and noticed that it was very hot at the top and Luke warm in the middle and bottom. I checked the other radiators and they were similar though no where as bad.
I am assuming this is built up sludge in the rads but no blockages to the pipes that I can see. My plan now is to isolate and remove the worst radiator and blast it with water to see how much sludge is in it.
I am a bit unsure of the next steps after that assuming I actually don't need a power flush.
I am a little bit confused about the sentinel products (i.e. X100, X200m X400). Which should I use and should I be thinking of a full flush of the system via the radiator drain points on the ground floor?
Also Should I be thinking of installing a Magnaclean filter even though we plan of changing the boiler in about a year as part of an extension?
