Hi guys - I'm after a bit of advice. I'm a competant DIY'er but have little knowledge of Central Heating pipe layouts
I have an open vented system used to heat 5 rads and hot water cylinder. the e problem I have is the system is noisy and always needs air bleeding from the rads. The air is being drawn thru the vent pipe when the pump turns on, I've turned the pump speed down and I still get air into the system.
The Feed and vent pipes are on the left of the picture, The vent is T'd into the inlet side of the pump and the cold feed is T'd into the the return pipe (i think). Do I need to move the cold feed to be between the vent and the pump ?
Any help or advice would be appreciated.. View media item 58308
