Hello, Not sure if I should post this here or in the central heating and plumbing section?
Earlier this morning I went to put the heating on (Summer is over let's face it!). After about 10 minutes the boiler cut out. I couldn't get it back on by switching the mains on and off. I decided it must be the fuse in the FCU. I replaced the 3amp fuse with one that works and the boiler fired up. Only issue is now the controller and thermostat have no power!
If it helps the boiler is a baxi avanta 15H, controller is drayton LP241 and thermostat is Corgi STTRSN-C.
Hopefully its something simple I can fix. Cheers in advance!
