Well I'm not too cold yet but the house is defiant cooling down!!!
I have a fairly conventional gas fired boiler (1989) pumped from upstairs with a diverter valve for central heating / hot water, and a mains-pressure sealed hot water tank.
The heating was working fine until this afternoon. This failure was quite sudden. The switching system (timer plus thermostat all seem to be working fine). The boiler still fires up (until it gets too hot) but the water doesn't seem to be getting to the radiators or the hot water tank. The heating cistern (in the attic) has water in it. When I bleed the upstairs radiators, they bleed water immediately. The pump (Grundfos Type UPS15-50x18) seemed to be making an odd ticking type noise.
It was just after 4pm so I figured a plumber / heating technician wouldn't get to me today and decided to have a closer look at things myself.
I removed the pump seep cover and some water dripped out (good). The pump spindle spun (manually) quite freely. I removed the pump to have a gander myself. The inlet and outlet looked pretty clogged-up with glogging-up material (the inlet unsurprisingly, more so) but I didn't expect them to be spotless. The outlet piping before the shut-off valve had some significant-sized pieces of glogging material with the look and consistency of a crumbly brick. The water I collected from all the leaking when removing the pump (plus, on an ongoing basis, seepage from the outlet plumbing where the shut-off valve wasn't doing a perfect job) seems relatively clear with no huge amount of sediment.
When I refitted the pump and put a stethoscope to it is sounds as if it is spinning smoothly when the heating system is on (and in each of its three selectable speeds) - but for all I know it may not actually be spinning at all!?
I'm guessing, pump, diverter valve or blocked pipe.
inlet:
outlet:
Does anyone have any ideas / prognosis /questions please?
inlet:
outlet:
