central heating high pressure
17 Nov 2015
Hi the water pressure in our central heating system was showing 3 bar, 4 hours after the boiler switched off. I have relieved some pressure using the valve on top of the Opticon gauge but it creeps back up to 3 bar when the boiler is running. not sure if this is connected but the oil boiler makes a loud pop every time it switches off. we also have issues with the boiler lock out light coming on. any thoughts please? thanks in advance
Tbh you need an onsite visit by an expert on your appliance (y)
When was the appliance last serviced, it may not have been serviced (n) to a decent standard but you have documents for that.
easy fix thou :giggle:
thanks are you referring to the boiler or the central heating?
