I'm hoping someone might be able to offer some central heating/hot water advice.
I've recently moved into a new house with my wife and 1yo boy. It's an 1870s terraced property in Stoke Newington (London). The central heating system we currently have is 20+ years old and in need of replacement.
The house is big and pretty poorly insulated (although we're about to repair/replace/upgrade all the windows). It's split level but generally can be considered to cover 3-4 floors. All the rooms are large with high ceilings. E.g. 17 ft x 15ft with 12ft high ceilings. There are 5 bedrooms and all have radiators (some single, some double, a couple with thermostats, most as old as the heating system). Our current boiler is an open vented stored hot water system. It seems to work ok but is outdated.
We'll definitely stay in the house for at least 5-7 years and likely much longer (10-20). We're hoping to have another nipper or two over the next 3-4 years but definitely no more than that. So we'd probably end up being a 4-5 person family. Next year we plan to extend the existing kitchen (which is relatively small) into a large open plan kitchen/diner (25ft x 20ft) where we'd spend much of our time. It's also worth noting that if ever we wanted to we could develop the loft which we'd likely convert to a large bedroom or studio with en suite.
My question is, given all this information what kind of system should we look to install to meet our likely needs? For example, I have friends with similar properties who are use systems like Megaflow. Are these recommended?
All advice and ideas much appreciated.
JD
JD
