Central Heating Leak
16 Mar 2008
Newcastle upon Tyne
Does anyone know if you can use a leak sealent solution on central heating systems installed with pushfit barrier pipe? My combi is losing 1.0 bar of pressure over the period of about 2 months, i've checked all accessable connections but found no leak. I suspect it may be under the floorboards at ground level because there is no visible water damage. Any words of wisdom?
Have you checked the presure relief valve(15mm pipe going outside) is not dripping?
Yes it will work on hep2o
