Central Heating Making Gargling / Water Running Noises???
28 Nov 2006
Birmingham
Hi all,
Some of my radiators have started making what I can only describe as gargling/water running noises when it is on. It is at its worst when it first comes on in the morning. All works fine but slightly concerned about the noise and could do without it as it wakes me up!!!!!
Can you please advise what the problem might and what I can do to overcome this?
Thanks.
could be air in the system. try bleeding the rads.
if you have air in them, you had best check the pressure gauge on boiler (assuming you have a combi boiler?) as if there was a lot of air let out, the central heating circuit pressure may drop below operating level and you'll have to top up again. usual pressure when hot and running is about 1-2 bar for most boilers i believe.
When you bleed them, what colour is the water?
Thanks for the help chaps.
I am planning on bleeding the rad's this weekend but this has brought up a further question. I was expecting my rad's to have bleed valves at the top, but there aren't any??? Any ideas???
Thanks.
IGNORE MY LAST POST!
Been a long day and just spotted the plastic cover that reveals the bleed valve!!!
