Hello all,
Hopefully this is child's play for some bright spark.
This is the situation:
Baxi Potterton boiler, central heating enabled on boiler, underfloor heating, thermostats in individual rooms cranked right up, heating does not work in any room.
The problem:
Hot water appears to be reaching the manifold. The areas indicated in red in the picture below reflect those which are very hot to touch:
http://www.eurochangecharity.org/manifold.jpg
The plastic tubes directly beneath each valve feel cool to touch, though I do not know whether this is by design or not. The tubes in the upper part of the picture disappear down into the floor, and directly in front of where they do, their sister tubes emerge back up from the floor and are shown in the lower set which are coloured in red/blue accordingly. Needless to say the pipes going into the manifold and coming back out of the manifold into the boiler are also very hot to touch, though I did not show this in the picture.
So - can anyone tell me what might be happening? If it helps with the answer, I haven't had the heating switched on for over 12 months. I first thought of blocked pipes - but surely not in all 6 rooms? Too much of a co-incidence, hence my suspicion over something to do with the manifold.
Any pointers greatly appreciated,
Steve[/img]
The problem:
Steve[/img]
