Hello everyone. Time for my yearly fight with my heating system! It's exciting! It's unpredictable! It's a rollercoaster of emotions!
I'll reiterate so that no one has to read through all these old messages.
ISSUE
Sealed combi boiler central heating system with 8 rads will run lukewarm if not touched. Heating may run for hours but the house never feels hot or fully heated and you need a jumper. Rads 'hot' at top but the bottom is cold or lukewarm. Worse at the end of the run (diagram in old post). also lots of gurgling, slurping, trickling noises especially when first turned on.
WORKAROUND
Last couple of years I've found that I can bleed the system almost daily and get more air out. If I do this when the system runs, it will fizz and spit as if air is in the water. For a while I turned off rads in succession and did this bleeding process, with the highest point getting the best resuls. After this the heating would get insanely hot, tropical, I'd need to take clothes off.
This year I've bought smart thermostats to try and simplify this process and I've found that if i turn off all rads except the last two in the chain, and let them run for 10-15 minutes from cold, I can the turn on the rest of the rads in turn and I'll get what feels like full performance from the system. house will be tropical in 30 minutes, compared to only lukewarm after an hour or two if I don't touch anything.
TROUBLESHOOTING
I've tried..
New boiler (5 or 6 years old now)
All new, and bigger rads, except one which I suspect is about 15 years old. Mostly Stelrad branded
Taken each rad off and flushed with hose
Had all the pipework replaced, and uprated to thicker, apart from two drops - the drop that comes from the boiler to the rest of the system and the drop to the last rad in the chain. Suspect original job was DIY.
Various balancing techniques
Tried isolating various rads to see if system is ok without a certain one in the chain - no difference
Added X400, X800 (different times) and drained as a treatment process
Most Recently..
Powerflush by heating company (grubby but not excessive)
Made sure the lockshield and thermostatic valve are the correct side of the rads, on supply and return
SUSPICION
It's almost as if there is an 'air lock' or some sort of block that exists until I leave only two rads on and 'force' that airlock through. I always always have slurping, trickling, ticking which drives me insane, suggesting there's air in there. this will be worst on the rads that are usually the worst the last in the chain. If I turn off all upstairs rads, the downstairs will make these noises.
Or there is corrosion in the oldest pipework that's generating some sort of gas..
OBSERVATIONS
No leaks, pressure doesn't drop or raise (unless I bleed or use the filling loop)
Magnaclean pulls some crud out but not excessive
There is inhibitor in the system, no difference between brands
NEXT STEPS
All I can think of to do is-
Get a deaerator fitted to see if this reduces air noises etc
Replacing the remaining pipework - about 2m drop at end, 2m drop that comes from the boiler
Exorcist or atom bomb
Does anyone have any ideas or advice. At least right now I can use the smart thermos to coax the heating to work but it's still inconvenient, I can't ever forget about it, and it's really noisy!
