- Joined
- 8 May 2017
- Messages
- 10,667
- Reaction score
- 2,872
- Country
If he cant find the FAQ 's ,he is gonna really struggle with finding dead mouse remnantsHe can't find FAQs
It at the top of the forum page in this section.
It would appear that your blockage has just happened.
Pete
Dont connect mains water. Pump running is a separate issue and can be looked at later. Firstly Sort out the blockage ,which will be somewhere on the pipework from the bottom of the f&e tank which feeds water into c/ heating system / boiler. If you have a strong magnet ,run it along the copper pipe ,it will be attracted by the blockage in the pipe which is invariably magnetite. Usually found near the first "T" on the pipework ,but not exclusively there. Isolate the electric supply to the boiler to stop pump from running ,if you havent already done so.
Stopcock blocked ? Please expand on that. You probably have not got all the blockage out from the pipework ,how did you go about it ? All other syptoms ,pump dry ,boiler cuts out etc is all down to no circulation / lack of water.
Chemical cleaner wont do much if you cant get circulation. This stopcock ,can you post a pic of it ? What is it isolating exactly ? What and where is the drain hose connected to ? Can you post pics of the pipework you worked on and the pump position in relation to it ?
Almost certainly wrong. The blockage is likely to have developed aver an age. It only comes to light when the system is drained, or water leaks or evaporates until the water drops below a critical level.
It is possible for a competent DIYer to sort out, but the posts to date imply, to me, that this is a little out of the OPs range.
It would be very unusual for a mains cold water pipe to be blocked. Is the " stopcock " a wheel head ,gate valve ?They are total krap.
Draining down the system as you describe would empty pipes and rads above ,but not necessarily those on the same floor .
Pull the pump out and clean the impeller its probably blocked... also get some form of “magnaclean” as your system is probably full of bits!
Yes I did that last night and the impeller is free with no residue. I did consider a flush but it won't fully drain so I think there is an air lock somewhere or the fact that I freed up the system by unblocking it, it could have caused another blockage. So I don't think I will be able to flush it properly anyway.
