Central Heating Pipe - clipping
21 May 2006
My recently installed central heating system - is making a few clips/taps/knocks when heating up.
I know it can be normal as we have copper pipes / wood floors etc.
If some of the pipes under the floor boards are movable (ie u can flex some VERY easily side to side) and there are no clips or ties etc anywhere. Can i safely add some of the little U clips u can buy from DIY places to secure and reduce movement and hense noise?
If i resrict movement with the clips can the pipes split as they cannot move as much when they expand / contact ???
Advice please !
Cheers
i find it best to get some hessian and wrap the pipes under the floor to stop this
i find that whacking clips on them only makes the noise worse as you are ramming the pipes up against the wood and there is no room for them to expand so they push against the wood and give you your noise
