Noticed tonight that the central heating isn't working. We have two 'sliders' - one turns on hot water, the other central heating.
Usually just turn on CH and set the thermostat to the temerature we want (you hear the thermostat click when it passes the current temperature and the boiler fires up).
Any way, what is happening now, is that the thermostat still clicks when you turn it past current tempertaure, but the boiler doesn't fire up.
However, if you turn on hot water (as well as central heating), the boiler fires up and the hot water gets hot, and more importantly the heating system gets hot.
I assume from this that (a) the boiler works, (b) the central heating pump works as the hot water in the tank gets pumped through the heating.
I thought maybe it was the thermostat not telling the boiler to fire up.
Boiler is a Potterton Promax HE (means nothing to me). The controller with the timer and CH/HW sliders on is in the kitchen under the boiler and the thermostat dial is at the foot of the stairs. Sure this isn't relevant but gives people an idea what it is that is malfunctioning.
What does everyone else think?
We are in rented accommodation (so the landlord is going to get someone to fix the problem - I already called him), but I am curious as to whether it is likely to be something simple or not and what others think.
