P
PottertonPrima30B
Hello Kevin,
sorry as i'm new to this i'm not quite sure how to answer your e-mail yet so i've done it this way instead!
Thank you very much for your Professional Advice & let there be Heat !!
The gray acl box is placed lengthwise on top of a pipe with the bottom section 'cut out' on the left hand side (as you look at it) incorporating a black lever which was sticking out to the right. I applied some pressure to it and it pulled back towards the left and it pushed back into the grey acl body. It's a bit difficult to see the end due to it's position in the airing cupboard however using a mirror i can see there are no markings on the gray box casing. This leads me to believe this black lever is possibly some form of a pressure release valve ?? as it was quite firm to push back in and i can't see how it could have been moved otherwise ??
The heat started to come into the radiators within 30 seconds and they are still all piping hot an hour later. I can also hear the pump running nicely.
May I take this opportunity to Thank You so much for taking the time to help me with this problem, you obviously have a great knowledge of this subject. May I wish you and your family a Happy Christmas & Best Wishes for 2010
