gonna go and order that part tmoz, and drain system half down and flick the c.u off to disconnect wires (after noting them)
the programer i , i want to be able to controll different days at diff times like
mon, tue from 5am to 8am, heating and water, * every 2nd week
wed thur not set as im not in house* every 2nd week
fri same as mon* every 2nd week
sat ,sun , to come on at 5pm till 10pm (both)
and vice versa the next week
the units that were mentioned was for heating on
i saw this one 1x ST9400C 7 DAY PROGRAMMER
the thermostat i have is a british gas one, can this be changed out for a digital one
i will fit the valve 1st and get the thing working,
to drain the system do i just block up the header tank in loft
open the drain cock outside to drain system and open radiator bleed valve,
the expansion tank with the pressure gadge , will that drain when i open the valve?
and might put inhibitor into the system, how do i add this, via header tank?
