When I select 'ch only' on my control unit the lever on the three port valve moves over to 'H' and the pump switches on/off according to the thermostat telling the pump when the room has reached/not reached temperature. When I select 'hw only' on my control unit (central heating off) the lever on the valve moves to 'W' and heats the water in the tank until it reaches temperature fine.
When I select 'ch and hw' the lever on the valve moves to 'H' and central heating is on fine, when the room thermostat clicks off, the lever stays in the 'H' position and the pump on, the heating stays on and the lever does not move over to heat the water.
I then selected the 'hw' off and put 'ch' on, which by itself works fine on and off according to the thermostat, when I turned the thermostat down the pump clicked off, I then switched 'hw' on via the control unit, the lever on the valve stays on 'h' and the pump starts heating up the rads even though the thermostat is not on.
Any ideas please - I did post earlier last week but this is now a better detailed description of fault.
