- Joined
- 10 Dec 2005
- Messages
- 2
- Reaction score
- 0
- Country
Hi Everybody,
About 18 months ago a plumber fitted a new circulating pump and motorised valve to my heating and hot water supply. This has worked very well until around 4 weeks ago. My heating and hot water is programable via a 'switchmaster' control panel. Now, when using this control panel I can set my hot water to come on but not my central heating. The only way I can get my central heating to operate is if the hot water is on as well. Consequently when my hot water has reached its high temperature, the central heating goes off with it. Result, to maintain my central heating, I have to constantly run off my hot water. I cannot set my central heating to come on independantly. Any help would be much appreciated.
Control : SWITCHMASTER
Thermostat control : SWITCHMASTER 9000 Electronic
Water Pump : Circulating Pump CP 53
Valve: SUNVIC 3 port Motorised valve
The SUNVIC Valve has a removeable actuator head which I have looked at and all the internal cogs appear to work.
Cheers Vivabossman
Cheers Vivabossman
