Central Heating Programmer
24 Nov 2008
I have just purchased a IFLO c/h programmer and on reading the wiring instructions it quote " make sure mains input has a 3amp fuse ".
My question is a 3amp fuse does not seem large enough to run a Trianco boiler, pump and 3 port share valve, so is the programmer and it's relay contacts be good enough to run the above :?: [/b]
3 amp fuse is plenty man enough to supply a gas ch system.
If it is oil, as you say Trianco, then the usual fuse for oil systems, I believe, is 5 amp.
