Central Heating- Radiators going cold one by one
bloody good try help people then they wanna go to bed.
maybe i'll try that get halfway through a days work then say im going home to bed now see ya when i feel like it. :roll:
The best way to find the pump is to follow the two pipes coming out of the boiler!
The pump will definately be connected to one of them!!!
I always wonder what calibre of people you have had looking at it?
Its most unlikely it would have been fitted as a gravity heating circuit if it was installed after 1959. Does it use steel screwed pipes or copper? Hint only one of these is attracted to a magnet!
Tony
Hi we have ascertained the boiler is in the kitchen and the hot water tank is above in an airing cupboard. To the left is a bedroom with a built in wardrobe where two of my neighbours say their pumps are in. We have looked in there and there is no hatch.....is it feasable that they have removed the hatch and put new floorboards in...they seem to go all the way across this built in cupboard.
The only option seems to be on the right of the hot water tank is the bathroom but this has a sealed tile floor
It could be anywhere! Stupidity knows no bounds!
have you looked BEHIND the cylinder ( tank )?
I met one fellow who fitted laminate flooring when he KNEW the pump was under the floor!
Tony
Tony, Thankyou for being so helpful, I will look behind the tank when I get home and then see if I can pull one of the floorboards up in the wardrobe in the bedroom. Failing that it looks like we are going to have to get the tiles up in the bathroom.
Be more guided by the neighbours if their systems seem to be similar.
Tony
Hi Tony, Looked in the cupboard under the floorboards but nothing...we think the only place they could be is under the bathroom so we're going to have to pull the flooring up this weekend but thanks for your help
As I said before, follow the pipes from the boiler!
Tony
