its a common fault on these if you have any electrical indifferences in the system.
An easy way to test is to disconnect one of the thermostat wires going to the zone valve. If the valve stays open, the problem is with the zone valve.
Honeywell zone valves are particularly notorious for sticking either open or closed. This is due, 99% of the time. to a bad motor. The motor is far less expensive than a whole powerhead or zone valve. Replacing one takes me about 5 minutes. Shouldn't take you more than 15 minutes.
