Y plan central heating problem
20 May 2009
Staffordshire
My central heating system works fine except that when the heating or hot water is switched off by the programmer the pump continues to run constantly. I have replaced programmer and 3 port valve without any improvement. I guess that the pump should run for a number of minutes after the system turns off in order to cool the boiler but I dont know what controls this. Has anyone any ideas?
Not all boilers have pump overun & the ones that do the pump live is controlled by the boiler. What make is your boiler?
The boiler is a Baxi Solo. I've managed to find a manual on the "net", I believe that the main thermostat could be the source of the fault. What do you think?
Thanks for your reply.
Depending which Solo it is, I would suspect the pcb, especially if it is a Solo 3.
The pump is wired to and controlled by the pcb.
Thanks Dave,
I had a look at the PCB and found a loose connection, so I tightened it up and fingers crossed I think the problem is solved
Brill thanks for your help.
