am building a timber frame home. have radiant heat installed in concrete basement. will have radiant heat under main floor which is 1"OSB subfloor. house is insulated with Sipco. basement is eco-foam block.
can i install ceramic tile over a layer of felt paper over the OSB? or should i use hardiboard or cement board? don't want the tiles to crack but don't think i want the radiant heat to go through another 1/4 to 1/2 layer with the layer on top of the OSB.
any ideas appreciated. thanks
