    Dismiss Notice
CH boiler replacement . System or open vent?
Discussion in 'Plumbing and Central Heating' started by elmsoft, 9 Jun 2020.
  1. elmsoft
    elmsoft
    3 Mar 2008
    199
    Thanks Received:
    9
    Gwynedd
    Country:
    I'm planning on upgrading my CH boiler, currently an open vent set-up with header tank etc. I don't want a combi but a sealed system seems simpler, an obvious choice. Why would I bother with a header tank if I don't have to?
    Is there any advantage of header tank /open vent set-ups or are they just a hangover from the past?
  2. ianmcd
    ianmcd
    15 Aug 2010
    17,069
    Thanks Received:
    6,485
    Lanarkshire
    Country:
    An open vent constantly fills your system if you have a leak, a sealed system will shut down if you have a leak, changing from open vent to sealed can actually cause leaks, because they operate under different pressures, speak to your installer and see what he /she recommends, the choice of boilers if you go with sealed systems is far greater than open vent systems, as sealed systems are the norm these days
    • Thanks Thanks x 1
  3. Sponsored Links
  4. elmsoft
    elmsoft
    3 Mar 2008
    199
    Thanks Received:
    9
    Gwynedd
    Country:
    Sounds like a comprehensive reply. :) Thank you. I guess if I have a leak I would want to know. And even if it is a weakness that might leak, probably as well to find it now. :)
    Thank you.
  5. WestmidsDIY
    WestmidsDIY
    27 May 2020
    15
    Thanks Received:
    3
    Country:
    If you have any heating pipes in concrete floors or hard to access, open vent is the better option..
    • Thanks Thanks x 1
  6. Sponsored Links
  7. ScottishGasMan
    ScottishGasMan
    22 Jan 2007
    6,571
    Thanks Received:
    2,396
    Country:
    A properly fitted and treated open vent system is in my mind the most reliable you will get. Different factors come into play such as age of system and access to pipework and budget, as once you pressurise it, if there are problems then its too late to go back, you can end up having to replace a lot of pipework or fittings.
    That being said, lots of systems convert over no problem, the issue is theres no way to know for sure before you do. Make sure if you do go down the sealed route that the expansion vessel fitted is big enough. Its the most common installtion fault you get nowadays when fitters rely on a built in vessel thats often not big enough for a system, which will cause all sorts of issues.
    • Like Like x 1
Loading...
Share This Page
