Hi
I'm installing a DIY heat pump alongside an existing vented CH/HW system & I'm getting a small pump over from the expansion tank.
I've raised the expansion pipe as far as I can in the roof space & the circulating pump is set to its lowest setting but still get a small pump over.
Can anyone see why I can't use an inline DBV in the expansion pipe, which will only open when the pressure in the heat pump circuit exceeds say 0.5 bar (ie on heating up)?
I looked for pressure relief valves but these all seem to be for unvented systems in the 3 - 5 bar range; too high for my system.
