Hi, I'm after a bit of help please.
We are having a bit of a problem with our heating. The rads don't stay on long enough to for the house to reach the temp set by the thermostat (20 degrees). It seems like that once the water reaches it's desired temp it, the heating is turning off as well. So the rads stay warm for a little while but then go cold again. They only seem to come back on once the water has cooled or perhaps a bath is run and so the boiler comes on to reheat the water.
I've changed the thermostat (old) and also the programmer (broke) but still the same problem exists. From doing a little research on the forum it seems that it could be a problem with the 3 port valve? The current one is a honeywell v4073a, this is the original one from when the house was built 20 years ago. When in use the valve/actuator does get warm/hot to the touch. Could it be the motor has packed in or is it possibly the whole valve that needs replacing?
Am i on the right lines or could there be another possible solution?
