CH layout of cold fill and vent pipe
Thanks for the sundial stuff Kev, great if I want to spend a fortune on loads of controls just to save a few shillings on gas. however, it's my elderly relatives house, so every shilling counts and he won't be around long enough to see the savings (unfortunately)
put the pump in the flow connected as dia suggests
after the pump a tee one leg to cylinder with a balancing valve on return
other leg to heating thro mv
make sure cyl return is nearest boiler
not really the way to do it mind
building regs and stuff :wink:
Thanks Kevplumb, lucky you living in Tenesse! bet it gets hot there in summer don't it?
View media item 649 nice veiw tho
during the day it can hit 95 100 difference is the humidity and the fact it doesnt cool down that much overnight
you can sit on the porch at 4 am in a pair of shorts quite comfortable :wink:
with a cold beer if err indoors is still in bed :lol: :lol:
I'm happy to connect the pipes on the flow circuit as you experts suggest ie boiler, vent, feed, pump, cylinder tee, heating tee with valve in.
However, your advice seems to contradict the 'three Tee rule' where it states the cold feed goes closest to the back boiler on the return............is this rule out of date/not compliant with latest building regs/wrong?
