- Joined
- 17 Jan 2016
- Messages
- 114
- Reaction score
- 4
- Country
Hi. In the last couple of days, my 2-year-old Worcester Bosch boiler has switched itself off and only switching the HW on will reignite the boiler and get the water circulating. Once the HW has reached temperature the boiler switches off and the radiators cool down. I reset the boiler today and it ignited but would only stay that way for a short time but once again switching on the HW worked for a while. I had the reverse situation last summer where the HW would only heat up if the CH was on. It turned out that the Honeywell motorised valve actuator needed replacing and everything was fine (surely the actuator hasn't failed already). I should add that the expansion tank next to the Heatrae Sadia cylinder is reading 0.2 bar and has been quite low for some time. At one point I suspected the Potterton EP2002 timer, but I'm not so sure now.
Help, please.
Help, please.
