Hi- Putting 100mm Jabfloor on a concrete slab. Now.... not sure if this is a flooring or plumbing question, but....
Jabfloor states It is permissible to accommodate services within the thickness of the insulation provided pipes etc. are securely fixed to the
concrete floor....not closer than12mm to hot water pipes..... and independently lagged. OK, but-
Has anyone experience of this? Is there an easy way to cut out channels in Jabfloor, to nestle accurately on top of the pipes/ lagging? I don't want the Jabfloor to dip causing the screed to crack on top 'cos there's ruddy great gaps/less Jabfloor support around the pipes underneath.
Thanks!
Thanks!
