Central heating pipes under concrete floor.
15 Dec 2009
Kent
Hello all.
I intend to lay some copper central heating pipes under my concrete floor.
As the screed depth is quite shallow (around 40MM) I can't use ducts or make a plyboard tunnel as I intended
Therefore I am thinking of just securing the pipes to the concrete slab below with pipe clips. Then I will just lay the solid floor on top which will be held up by the screed either side. The pipes should not be in contact with the floor or any concrete and there will be around 5mm gap above them to the flooring.
Does this sound like an OK plan?
Thanks for any help.
22 Jan 2007
Sounds ok as long as the channel isn't too wide. Insulate the pipes though, there should be enough room for 9mm foam insulation.
15 Dec 2009
Kent
Thanks for the advice.
Does anyone have any ideas on how I can repair the screed?
I'm guessing some sort of sand/cement mix, could someone advise on a specific product please? A bag of ready to mix or something. I've not done something like this before.
I have to build up the edge so that the floor board will have something to sit on.
22 Jan 2007
It wont be seen, use 4 parts building sand to 1 part cement.
15 Dec 2009
Kent
Thanks again.
Do you reckon there would be any issues with putting a DPM under the pipes?
22 Jan 2007
Not really required, but no issues.
15 Dec 2009
Kent
Thanks for the tips.
It's just because of the oak flooring going on top, it says to put a DPM underneath.
22 Jan 2007
Won't do any harm but there should be one within the floor anyway. If the flooring instructions say it then go for it. Better safe than sorry.
